Assigning Related Items to Documents without the Content Repository
You can assign related activities, WBSs, issues, and documents to a document.
To assign related items to a document:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page:
- Expand a project and select a document.
- Click the Related Items tab.
- On the Related Items tab:
- To relate activities or WBSs, click
Relate Activities or WBS and select activities or WBSs from the Select an Activity or WBS dialog box. - To relate issues, click
Relate Issues and select issues from the Relate Issue dialog box. - To relate documents, click
Relate Documents and select documents from the Relate Document dialog box. - Click Save.
Tip:
- Documents assigned to activities are visible to team members using P6 Team Member.
- You can also relate activities or WBS nodes to documents in the Documents detail tab of the activities page.
