Assigning Resource Codes
With potentially hundreds of resources in use across the enterprise, resource codes provide an efficient means for tracking and sorting resources for reporting or analysis.
Use this procedure to assign resource codes to resources. Once assigned, you can categorize resources using codes.
To assign resource codes:
  1. On the "" Navigation Menu, expand "" Resources and click Administration.
  2. On the Resources page, click Resources.
  3. On the Resources tab:
    1. Click a resource.
    2. Click the Codes detail window.
  4. On the Codes detail window, click Assign....
  5. In the Select Resource Code dialog box:
    1. Expand a resource code.
    2. Select a code value and click Select.
      • The top levels of the hierarchy in the Select Resource Code dialog box represent resource codes. All lower levels of the hierarchy represent resource code values.
      • You can only assign one value from each code to a resource. If you try to assign a second value from the same code, the first value will be replaced with the new value.
  6. Click Save.
