Assigning Resources to an Activity
Perform these steps to assign one or more resources to an activity.
To assign resources to an activity:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select an activity and click the Assignments detail window.
Tip:
- When you assign a resource to an activity that does not have any resource assignments, the resource is identified as the primary resource. If you subsequently assign more resources to the same activity, you can change the primary resource assignment for the activity by selecting the Primary Resource option for one of the resources in the Assignments detail window. If the Primary Resource option is not displayed in the Assignments detail window, click
Customize View to add the column to the window.
- When you assign a resource to an activity, if that resource has a primary role, the assignment includes the resource's primary role.
- When you create, delete, or modify a resource assignment, your changes are automatically saved when you select another activity. You will not be able to undo the changes after selecting a different activity.
