Assignment % Complete
Assignment % Complete field
The percent complete for the assignment. The calculation of this field depends on the percent complete type for the activity.
If the activity's percent complete type is Units % Complete, this field is calculated as Actual Units for the assignment divided by the At Completion Units for the assignment. If the assignment is not started, the Physical % Complete for the assignment is zero. If the assignment is completed, the Physical % Complete is 100%. If the assignment is completed and the actual units are zero, the Physical % Complete is also zero.
If the activity's percent complete type is Duration % Complete, this field is calculated as (Planned Duration of the assignment - Remaining Duration of the assignment) / Planned Duration of the assignment.
If the activity's percent complete type is Physical % Complete, this field is equal to the Physical % Complete for the activity.
Required for IPMDAR.
