Bubble Chart Settings Area
The Bubble Chart settings area displays configurable options for viewing portfolio data in a bubble chart. Use the following fields to modify your bubble chart view.
Bubble Chart Settings:
X Axis list
Select a field value to determine information displayed through the X Axis.
Y Axis list
Select a field value to determine the information displayed through the Y Axis.
Group By list
Select a field value to determine your preferred option to group your data.
Bubble Size list
Determines the size of bubbles that display in a Bubble chart.
Color Theme list
Determines colors displayed on the chart. Select a predefined or user-defined color theme.
Horizontal Gridlines option
Determines whether to show or hide horizontal gridlines.
Vertical Gridlines option
Determines whether to show or hide vertical gridlines.
Show All Values on Axis option
Determines whether all values are displayed in the histogram. Select this option to include all values on the X-axis and not just values with data.
