Changing the Calendar Type
You can change the type of calendar you created from a personal calendar to a global calendar or shared calendar, or a shared calendar to a personal calendar or global calendar.
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Resources and click Resource Calendars.
- On the Resource Calendars page, expand Personal Calendars or Shared Calendars and select a calendar.
- Click
Context and select Promote to Global Calendar, Convert to Shared Calendar, or Convert to Personal Calendar. - Click Yes to confirm the calendar change.
- Click Save.
Tip:
If you promote a calendar on the Resource Calendars page to be a global calendar, it will no longer appear on the Resource Calendars page. To see the calendar, expand Global and click Global Calendars.
