Configuring Activity Code Values
Configure activity code values to reflect changing variations within the larger scope of the activity code.
To configure activity code values:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Activities, then:
    • Click Activity Codes - EPS, expand an EPS node, then expand a code.
    • Click Activity Codes - Global, then expand a code.
    • Click Activity Codes - Project, expand a Project, then expand a code.
  3. Select an activity code value.
    1. In the Name field, double-click and type a name for the code value.
    2. In the Description field, double-click and type a brief narrative about the code value.
    3. In the Color field, double-click and select a color.
      In the Gantt chart and the Activity Calendar, activity status shown by activity code will display the color you apply to the activity code value.
  4. Click Save.
Tip:
  • Activity code values at the same level are siblings. Subordinate activity code values are children.
  • You can also configure activity code values from the Codes detail window on the Activities page.
  • If you are working on the Activity Codes - Project page and the project you need is not visible, click ""Open Project. In the Open Projects dialog box, select a project from the Available Projects list, click "" to move the project to the Selected Projects list, and click OK.
