Configuring Advanced Scheduling Options
Configure advanced scheduling options to define float paths.
To configure advanced scheduling options:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page:
Tip:
- You can select any activity in the Display Multiple Float Paths ending with activity dialog box; however, typically this activity is a milestone or some other major activity in the project schedule.
- To optimize performance, type a low number (10 or less) in the Specify the number of paths to calculate field.
