Configuring Allowed Client IP Address Ranges
You can create a limited list of client IP addresses that will be permitted to call P6 EPPM Web Services.
This ability is available only to P6 EPPM Web Services. The restriction is applied only when the Enable web services option is selected. When Enable web services is not selected, all clients will be permitted to connect to P6 EPPM Web Services (assuming they have valid authentication credentials), regardless of their IP address.
To add an IP address or range, complete the following steps:
  1. On the "" Navigation Menu, expand "" Administration, then click Application Settings.
  2. On the Application Settings page, click Integration & Allow Lists.
  3. On the Integration & Allow Lists page:
  4. In the Enable allow list filtering for web services section, click Edit List.
    1. In the Edit Allow List dialog box, click Add and enter a specific IP Address or IP Address Range.
      Enter IP addresses in Internet Protocol version 4 form format. Enter IP Address ranges using Classless Inter-Domain Routing (CIDR) notation.
    2. Select the option next to an IP address or range to allow it to interact with P6 EPPM Web Services.
      Clear the option next to an IP address or range to prevent it from interacting with P6 EPPM Web Services.
    3. To delete an IP address or range from the list, click  next to it and choose Delete.
    4. Click Save.
Tip:
The entire allow list can be enabled or disabled by selecting or clearing the Enable web services option.
