Configuring P6 Team Member View Preferences
Configure the Team Member view preferences to enable users to view and update the fields that are important for statusing the project in P6 Team Member Web, P6 for Android, or P6 for iOS.
To configure view preferences:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
- Time Spent is read only if the Team members enter new actual units option is selected.
- If reviews are enabled for status updates and you allow team members to add or delete steps, the status reviewer is prompted to approve the change of a step name; however, steps that are added or deleted by a team member are not submitted for review.
- The assignment and activity fields display in P6, Email Statusing Service, P6 for Android, and P6 for iOS in the following order, if selected:
- The activity codes and UDF fields will appear in the P6, Email Statusing Service, P6 for Android, and P6 for iOS interfaces in the same order as shown on this tab.
- Expected Finish
- Activity % Complete
- Remaining Duration
- Actual Units or Actual Labor Units
- Actual Nonlabor Units
- Remaining Units or Remaining Labor Units
- Remaining Nonlabor Units
