Configuring Dashboard Content
You can determine which portlets appear on a dashboard and how they display their information. Your changes apply to all users of the current dashboard.
To customize dashboard content (select the portlets you want to appear):
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, click Customize.
- On the Dashboard Details page, click the Content tab.
- On the Content tab:
- Expand the General section to modify the dashboard title and its filters, or to specify the maximum number of rows displayed in portlets.
- Expand the other sections representing the data of interest to users of this dashboard. For example, Resources.
- Select the portlets you want to display by checking the box adjacent to the name of the portlet.
- For portfolio view and custom portlets, click Add.
- Expand a portlet name to configure its options, fields, and lists that determine what will display on the dashboard. Click Customize if available for the selected portlet.
- Click Save and Close.
Tip:
The default maximum number of portlets you can display in a dashboard is twelve; however, your administrator can specify a different maximum.
