Configuring Eventing Settings (On Premises Only)
Configure eventing settings to specify the destination security and directory services and to configure which business objects and special operations should trigger events.
To configure eventing settings:
- On the
Navigation Menu, expand
Administration, then click Application Settings. - On the Application Settings page, click Eventing.
- On the Eventing page, click the General tab.
- In the Eventing Section:
- In the Directory Services section:
- Double-click the field and type the Provider URL.
- Double-click the field and type the Initial Context Factory.
- Double-click the field and type the Lookup Name.
- Double-click the field and type the Security Principle.
- Double-click the field and type the Security Credentials.
- Double-click the field and type the Security Level.
- Click Test Connection.
- On the Eventing page, click the Configuration tab.
- Click Save and Close.
