Configuring Expenses
Configure expenses to update costs associated with an activity.
To configure expenses:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page, select an activity and click the Expenses detail window.
  3. In the Expenses detail window:
    1. Select an expense.
    2. Add or remove columns as needed to configure to the detail window.
    3. Select an option or enter a value for each field.
