Configuring Project Summarization and Publication Services
You can configure options for the project summarization and publication services.
To configure project services:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
If you clear the Enable Summarization option in the EPS table, you will be asked if you would like to delete the summary information. If there is no summary information, then the application will not prompt you.
