Configuring the EPS
Configure the EPS for your organization to develop a hierarchy that establishes the way your organization operates. Divide the EPS into multiple levels or nodes to represent the work that needs to be done in your organization. You can then assign projects to these nodes and levels to reflect work that needs to be done in each area.
The number of EPS levels and their structure depend on the scope of your projects and how you want to summarize and aggregate data. For example, you might want to define increasingly lower levels of EPS nodes, similar to an outline, to represent broad areas of work that branch into more detailed projects.
To configure the EPS:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
The farther to the left an EPS is, the higher-level EPS it is.
