Configuring the Standard Work Week for Resource Calendars
Configure the standard work week for the calendar to set the work and nonwork days and hours for a standard work week.
To configure the standard work week:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Resources and click Resource Calendars.
  3. On the Resource Calendars page:
    1. Click on the calendar you want to modify.
    2. Click the Standard Work Week tab.
  4. On the Standard Work Week tab:
    • Type the number of hours for each work day in the total hours field.
    • Or click and drag on the chart to create work periods for each work day.
  5. Click Save.
Tip:
  • You can create multiple work periods for each day.
  • You can delete a work period by moving your mouse over the work period and clicking .""
