Configuring WBS Earned Value
Configure earned value to define the techniques and settings used for earned value computations.
To configure WBS earned value:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page, select a WBS and click the Earned Value detail window.
- In the Earned Value detail window:
- Select one option for each technique section.
- If your selections enable fields, selectors, or options, select an option or enter a value for each field.
- Save your changes.
Tip:
To view WBS detail windows, group your view by all levels of the WBS.
