Constraint Date
Constraint Date field
The date for which the activity's constraint applies. Depending on the constraint type, this date could be a start or finish.
For example, for a Finish On constraint, the constraint date is the date on which the activity must finish. If the activity does not have a constraint, this field is empty.
