Cost Variance - Labor Units
Cost Variance - Labor Units field
The difference between the earned value labor units and the actual value labor units.
A negative value indicates that actual costs have exceeded the value of work performed.
Calculated as Earned Value Labor Units minus Actual Labor Units.
