Creating Baseline Types
Create baseline types to label and standardize the use of baselines across all projects at your organization.
To create a baseline type:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Projects and click Baseline Types.
- On the Baseline Types page:
- Click
Add. - In the Type field, type a unique type.
- Click Save.
- Click
Tip:
- Click
Context and select Move Up or Move Down to adjust the sort order.
- To change the name of a baseline type, double-click it and enter a new name. The change applies to any projects with baselines of that particular type.
