Creating Dashboards
Create dashboards to display portlets and data that pertain to your role. Multi-user dashboards are also available, including global dashboards for all users to share data.
To create a dashboard:
  1. In the context selector, select "" Dashboard and then click Manage Dashboards.
  2. On the Manage Dashboards page, click Create Dashboard.
  3. On the Copy from Existing Dashboard dialog box:
    1. Select Default Dashboard or an existing dashboard to use as the basis for your new dashboard.
    2. Click OK.
  4. On the New Dashboard page, click the Content tab.
  5. On the Content tab:
    1. Expand the General section.
    2. In the Dashboard Title field, enter a name.
  6. On the New Dashboard page, click Save and Close.
Tip:
Customize a new dashboard by configuring its content, layout, and user access settings.
