Creating Document Categories
Create document categories to organize documents. Each category serves as a folder for easy retrieval of the document.
To create document categories:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Documents and click Document Categories.
- On the Document Categories page:
- Click
Add. - In the Name field, enter a name.
- Click Save.
- Click
Tip:
- To change a name of a category, double-click the selected name and enter a new name. If you change a document category's name, the change is applied to all document assignments.
- To change the order in which a document category is displayed, select it, then click
Context and select Move Up or Move Down.
