Creating Document Folders
If P6 is configured to use the content repository, you can create document folders as a method of document organization in a project.
To create document folders:
- On the
Navigation Menu, expand
Projects and click Documents. - On the Documents page, click the Project tab.
- On the Project tab, select a project to which you will add the folder and click
Add Options and select
Add Folder. - In the Add Folder dialog box:
Tip:
You can also create document folders from the My Documents portlet of the Dashboards page.
