Creating Project Calendars
Create project calendars to determine work or nonwork time for a project.
To create a project calendar:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Projects and click Project Calendars.
  3. On the Project Calendars page:
    1. Click on a project.
      If the project you need is not open, click Open Project.... Choose one or more projects and click OK.
    2. Click "" Add.
  4. In the Select Calendar to Copy dialog box:
    1. Select the Global, Resource, or Project option.
      This determines which list of calendars you can select.
    2. Select a calendar and click Select.
  5. On the Project Calendars page, click the Calendar tab.
  6. On the Calendar tab, click in the Name field and enter a name for the project calendar.
  7. On the Project Calendars page, click Save.
Tip:
Configure the project calendar by modifying additional settings.
