Creating Resource Codes
Create resource codes to group and arrange resources.
To create resource codes:
  1. On the "" Navigation Menu, expand "" Administration and click Enterprise Data.
  2. On the Enterprise Data page, expand Resources and click Resource Codes.
  3. On the Resource Codes page:
    1. Click "" Context and select Add Code.
    2. In the Name field, double-click and type a unique code name.
    3. In the Secure field, select the option to make the code read-only for users without the necessary security privileges to make changes.
    4. Move the code to the correct location in the list by clicking "" Context and selecting Move Up, Move Down, Move Left, or Move Right.
    5. In the Maximum Length field, double-click and click the up or down arrow to specify the maximum length for resource code value names.
    6. Click Save.
Tip:
You can designate a resource code as secure only if you have the appropriate security privilege; otherwise, this option does not display.
