Creating Risk Categories
Create risk categories and subcategories to define a risk breakdown structure (RBS), which enables you to categorize and organize project risks.
To create a risk category:
- On the
Navigation Menu, expand
Administration and click Enterprise Data. - On the Enterprise Data page, expand Risks and click Risk Categories.
- On the Risk Categories page:
- Select an existing category and click
Add
and select Add to create a category at the same level, or select Add Child to create a category below the selected level. - In the Category field, double-click and type a unique name.
- Move the risk category to the correct location in the list by clicking
Context and selecting Move Up, Move Down, Move Left, or Move Right. - Click Save.
