Creating Roles
Create a standard set of roles that you can assign to labor and nonlabor resources and activities.
To create roles:
- On the
Navigation Menu, expand
Resources and click Administration. - On the Resources page, click Roles.
- On the Roles tab:
- Click
Add, or click an existing role and click
Context then select Add Child Role to add a role in a hierarchy. - In the ID field, click and type a unique identifier for the new role.
- In the Name field, click and type a role name.
- In the Description field, click and type a description of the role's responsibilities
- To create or modify a hierarchy of roles, click
Context and select Move Up, Move Down, Move Left, or Move Right to position the new row.
- Click
- Click the Units and Prices detail window.
- In the Units and Prices window:
- Click
Add to add a new row to the table. - In the Effective Date field, double-click and select the effective date on the calendar.
- In the Max Units/Time field, double-click and type the maximum work units per time for this role.
- Configure the rate and price per unit fields fields for the new effective date.
- Click
- Click Save.
