Creating WBS Milestones
Create WBS milestones to specify goals for a project.
To create WBS milestones:
- On the
Navigation Menu, expand
Projects and click Activities. - On the Activities page:
Tip:
- The Percent Complete field within the WBS Milestones detail window indicates the percentage of tasks completed toward achieving the milestone.
- Use the Move Up and Move Down arrows to arrange the milestones.
- The weight you apply to a milestone is used to calculate the earned value of the percent of activities completed in achieving the milestone.
