Customizing the My Risks Portlet
Customize the My Risks portlet to determine which columns and filters to apply to the portlet.
To customize My Risks:
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, expand the My Risks portlet and click Customize.
- In the Customize Risks dialog box, click the Columns tab.
- On the Columns tab, select columns from the Available Columns list.
- In the Customize Risks dialog box, click the Filter tab.
- On the Filter tab:
- Select an option from the Display list.
- If applicable, select or clear the options.
- In the Customize Risks dialog box, click Save.
