Defining Indicators for User Defined Fields
Define indicators for user defined fields (UDFs) that will display based on criteria set for field values. For example, you can choose a graphical indicator to display when the value of the field equals a certain number, or when the value of the field falls between a certain range of dates.
You must create a project user defined field before defining an indicator.
You can identify graphical indicators only for fields with a 'Cost', 'Integer', or 'Number' Data Type.
To define indicators for UDFs:
Tip:
Click
Context and select Add to add another indicator statement or Delete to remove a statement.
