Deleting Entries
The steps for deleting any entry in the entire application, such as activities, steps, or users, are generally the same.
To delete an entry:
  1. Navigate to any table or list of entries in the application.
  2. Select an entry. To select multiple entries, press and hold the Ctrl key down as you click additional entries. Press and hold the Shift key down to select all contiguous entries.
  3. Delete the entry using one of the following generally available methods:
    1. Click "" Context and select Delete.
    2. If prompted to confirm, click Yes.
    3. If it becomes active, click Save.
