Durations Columns of the Assignments Table
Actual Duration field
The total working time from the assignment actual start date to the actual finish date for completed assignments, or the total working time from the actual start date to the data date for in-progress assignments.
At Completion Duration field
The total working time from the assignment's current start date to the current finish date.
The current start date is the planned start date until the assignment is started, and then it is the actual start date. The current finish date is the planned finish date while the assignment is not started, the remaining finish date while the assignment is in progress, and the actual finish date once the assignment is completed. The total working time is calculated using the activity's calendar.
Planned Duration field
The resource's total working time on the activity from the Planned Start date to the Planned Finish date.
Planned Lag field
The planned time lag between the activity's planned start date and the resource's planned start date on the activity.
If the resource is planned to start work when the activity is planned to start, the planned lag is zero.
Remaining Duration field
The remaining working time for the resource assignment on the activity, from the resource's remaining start date to the remaining finish date.
The remaining working time is calculated using the calendar determined by the activity type. Resource dependent activities use the resource's calendar; other activity types use the activity's calendar. Before the activity is started, the Remaining Duration is the same as the Planned Duration. After the activity is completed, the remaining duration is zero.
Remaining Lag field
The time lag between the activity's remaining start date and the resource's remaining start date on the activity.
If the resource's remaining work starts on the activity's remaining start date, the lag is zero. Before the activity is started, the remaining lag is the same as the planned lag.
