Earned Value Cost
Earned Value Cost field
The portion of the project baseline total cost of an activity or all activities in the project that are actually completed as of the project data date.
Budget at completion is calculated from the project baseline.
Calculated as Budget At Completion multiplied by Performance Percent Complete. The method for computing performance percent complete depends on the Earned Value technique selected for the activity's WBS.
