Exporting Resource or Role Usage Data
Perform these steps to save customized resource or role usage data from the Resources Analysis section to a Microsoft Excel spreadsheet (*.xlsx). All spreadsheet rows and the entire visible timescale are exported.
To export resource or role usage data:
Tip:
- An application level setting determines whether cost spreads account for changes in resource and role rates over time.
- For units display, if a resource code or resource team consists only of material resources with differing units of measure or a mix of labor, nonlabor, and material resources, the spreadsheet summary row displays dashes instead of totals. Summing unit values for mixed resource types does not provide an accurate total because labor and nonlabor resources are usually associated with time (such as hours or days), and material resources are often expressed in non-time units of measure.
