Exporting Risk Data
Risk data can be saved to an Excel spreadsheet (*.xlsx). All data is exported as it appears in the current view. Customize the rows to display only the data you want to export.
To export risk data:
  1. On the "" Navigation Menu, expand "" Projects and click Risks.
  2. On the Risks page, click "" Customize View to configure the fields, grouping, sorting and filtering to show in the exported file.
  3. Click "" Download.
