Exporting Team Usage Spreadsheets
You can export project team allocation and cost data to a Microsoft Excel *.xlsx file.
To export team usage spreadsheets:
  1. On the "" Navigation Menu, expand "" Projects and click Team Usage.
  2. On the Team Usage page:
    1. Choose whether to view Resource or Role data.
    2. Select an option from the Show usage for list.
    3. Select an option from the Display list.
    4. Expand the roles or resources you want to show in the spreadsheet.
    5. Click "" Download.
  3. In the File Download dialog box, click Open or Save.
    If you select Save, navigate to a file location in the Save As dialog box and click Save.
