Finding Entries
Another common feature of P6 tables is the Find command. Unlike the Search feature which shows you all matching results at once, the Find feature searches up or down in a column to find the next single matching entry.
To find entries in a table:
To find matching data on a page, however, use your web browser's Find command.
To find entries on a page:
- Navigate to any page displaying field data.
- In your web browser, select Find from the Edit menu.
- In the Find field, enter your search criteria and click OK or press Enter.
- Your matching search results are highlighted on the current page.
