Histogram Chart Settings Area
The Histogram Chart settings area displays configurable options for viewing portfolio data in a histogram, side-by-side histogram, or stacked histogram chart view. Use the following fields to modify your histogram chart view.
Screen Elements
X Axis list
Select a field value to determine information displayed through the X Axis.
Y Axis list
Select a field value to determine the information displayed through the Y Axis.
Color Theme list
Determines colors displayed on the chart. Select a predefined or user-defined color theme.
Horizontal Gridlines option
Determines whether to show or hide horizontal gridlines.
Vertical Gridlines option
Determines whether to show or hide vertical gridlines.
Show 3-D option
Determines whether to show a 3-Dimensional view of chart.
Show All Values on Axis option
Determines whether all values are displayed in the histogram. Select this option to include all values on the X-axis and not just values with data.
Group By list
Select a field value to determine your preferred option to group your data.This option is only available for the Side-by-Side Histogram view.
Stack By list
Determines the value by which the data will be stacked. This option is only available for the Stacked Histogram view.
