Importing Activities
You can import new activities into a P6 project from a Microsoft Excel (.xlsx) file. Create an import template, fill in the data you want to import, and save the file before before completing these steps.
To import activities:
  1. On the "" Navigation Menu, expand "" Projects and click Activities.
  2. On the Activities page:
    1. Click the Actions "" menu and select Import and then select Import from Excel.
    2. In the Import Activities dialog box:
      • Click "" Browse in the Import File field and select a file from the dialog box.
      • Click "" Select in the Select Project field and select a project from the dialog box.
      • Click Import.
    3. On the Activities page, click Save.
Tip:
The import file must be in Microsoft Excel (.xls or .xlsx) format.
