Lag
Lag field
The amount of time the predecessor activity was delayed, affecting the ability of its successor activity to start or finish. Lag can be positive (indicating a delay) or negative (indicating that the successor can begin a set time before the predecessor completes).
This value is specified by the project manager and is used by the project scheduler when scheduling activities.
