Linking P6 and Primavera Unifier Applications Using Activity Sheets
Perform the steps below to link P6 to Primavera Unifier using activity sheet integration. This link at the application level allows you to establish links at the project level. When the applications and projects are linked, Primavera Unifier users can exchange activity data with P6.
The first time you exchange data between P6 Professional and Primavera Unifier using activity sheet integration, you must initiate the exchange from Primavera Unifier. After the first time, you can initiate the data exchange from P6, P6 Professional, or Primavera Unifier.
To link P6 to Primavera Unifier using activity sheet integration:
- On the
Navigation Menu, expand
Administration, then click Application Settings. - On the Application Settings page, click the Gateway tab.
- On the Gateway tab in the Primavera Gateway Parameters section:
- On the Gateway tab in the Integration Parameters section:
- Click Save and Close.
Tip:
You need the Edit Application Settings privilege to edit the settings in the Application Settings page.
