Linking P6 and Primavera Unifier Projects and Schedule Sheets.
When the P6 and Primavera Unifier applications are linked, you can link projects in P6 to Primavera Unifier projects and schedule sheets. This will allow you to send P6 data to Primavera Unifier.
You cannot link a template project to Primavera Unifier.
To link a P6 to a Primavera Unifier project and schedule sheet:
- On the
Navigation Menu, expand
Projects and click EPS. - On the EPS page:
Tip:
You need the Allow Integration with Primavera Unifier privilege to change any of the settings on the Primavera Unifier page of Project Preferences.
