Maximum Percent to Over Allocate Resources
Maximum percent to over allocate resources field
The maximum percentage by which resource availability can be increased.
You can make adjustments to this field value each time you level resources. For example, if an important resource assignment does not fit within the available float using your first over allocation limit, you can try again using a higher limit.
