Modifying Calendar Days on My Calendar
Modify calendar days to account for work or nonwork days or hours that are different from the standard hours defined on the Standard Work Week tab. For example, you might choose to specify vacation days by setting the standard working days to nonworking days.
To modify work or nonwork calendar days:
- Click the User menu and select My Calendar.
- On the My Calendars page, click the Calendar tab.
- On the Calendar tab navigate to the day or days you want to change.
- Click Save.
