My Reviews Toolbar
Overview
The following icons and screen elements appear in this toolbar; however, their availability is subject to change based on your current selections, view settings, security permissions, window type, and other factors.
Screen Elements
Edit Details
Enables you to view and configure the details of the selected document.
Terminate
Stops the selected document review and removes it from view.
Filters
Enables you to reduce the number of values displayed in a list or table by filtering out unwanted values. Select from one of the following options:
- In Review
- Approved
- Rejected
- All
