Navigating Using a Keyboard
You can use the keyboard to navigate throughout P6. Use the tab key to cycle through elements within the application, and press Enter to access them. Use application keyboard shortcuts to access frequently used or important functionality. Keyboard shortcuts may change depending on the browser you use.
General
- Ctrl + S: Save.
- Escape: Cancel.
- Delete: Delete a row in a detail tab or grid.
- Insert: Add.
- Shift + Insert: Add child.
- Ctrl + C: Copy.
- Ctrl + X: Cut.
- Ctrl + V: Paste.
- Ctrl + P: Print.
- Ctrl + Right Arrow: Expand.
- Ctrl + Left Arrow: Collapse.
- F11: Full Screen.
- Alt + Up Arrow: Move focus up.
- Alt + Down Arrow: Move focus down.
- Alt + Right Arrow: Move focus right.
- Alt + Left Arrow: Move focus left.
- Shift + F10: Access right click menu.
- F9: Schedule.
- Shift + F9: Leveler.
Picker Windows
- Ctrl + Left Arrow: Move currently selected nodes to the left.
- Ctrl + Right Arrow: Move currently selected nodes to the right.
Grids and Detail Tabs
- Up Arrow: Move focus to the node or cell above.
- Down Arrow: Move focus to the node or cell below.
- Ctrl + Left: Collapse group node or move to parent node.
- Ctrl + Right: Expand group node or move to first child node.
- Home: Move focus to first node in the tree.
- End: Move focus to the last visible node in the tree.
- Escape: Remove search string.
- Space: Select current node.
- Shift + Up Arrow: Add the row above to the selection.
- Shift + Down Arrow: Add the row below to the selection.
- Ctrl + Shift + Up Arrow: Move the currently selected or focused node up.
- Ctrl + Shift + Down Arrow: Move the currently selected or focused node down.
- Insert: Add.
- Ctrl + Insert: Assign.
- Ctrl + C: Copy row.
- Ctrl + X: Cut row.
- Ctrl + V: Paste row.
- Ctrl + Shift + C: Copy cell value.
- Ctrl + Shift + X: Cut cell value.
- Ctrl + Shift + V: Paste cell value.
- Ctrl + Alt + R: Assign Resource in the Assignments detail window.
- Ctrl + Alt + O: Assign Role in the Assignments detail window.
- Ctrl + Alt + Q: Open a Request for a Resource in the Assignments detail window.
- Insert: Assign successor or predecessor activity in the Relationships detail window.
- The shortcuts for moving a tree node are only available for trees which can be reordered.
- The shortcuts for extending a selection are only available for trees which allow you to select more than one node.
