Net Present Value
Net Present Value field
The difference between the present value (PV) of the future cash flows from an investment and its investment cost.
Present value of the expected cash flows is computed by discounting them at the required rate of return or discount rate. Positive net present value (NPV) is an indicator of projects that should be pursued.
Calculated as Total Benefit Plan (Present Value) minus Total Spending Plan (Present Value).
