Online Help
Online Help URL field
The help URL that will allow users to access help for P6 Professional. If this field is left blank, the Online Help option will not be available and Local help will always launch when the F1 key or Help shortcut are used.
Leave the default URL to launch the version of the help hosted by Oracle when Online Help is selected from the Help menu. Remove the URL to disable the Online Help option from the Help menu for all users. Users will only be able to access the local version of the help. Specify a new URL location to launch when Online Help is selected from the Help menu.
Using the hosted version ensures that you always have the most current help content.
