Opening Projects from Dashboard Portlets
You can open projects from within certain project-related portlets such as My Projects or Project Health. You must have OBS access, be the owner, or assigned as a resource or activity owner in the project. In these portlets, wherever the project name appears as a link, you can click it to open the project in the Projects section.
Not all portlets allow you to open projects in this fashion. For example, the Project Statistics and Schedule Performance portlets will not open the project when its project link is clicked. Instead, these portlets offer more detailed views into the data they represent.
To open a project from within a portlet:
- On the
Navigation Menu, expand
Dashboard. - On the Dashboards page, select a dashboard.
- On the dashboard, expand the portlet and select a project.
Tip:
- In scorecard Portfolio View portlets, click the name of the project you want to open.
- In the Project Gantt Chart portlet, hold down the Ctrl key to select multiple projects and click Open Projects in the portlet toolbar to open them.
