Parent Resource
Parent Resource field
A resource categorized at a higher level than the current resource, in a resource hierarchy.
The parent resource is generally the larger department or organization for which you work.
For example, a salesperson might be assigned to an element of the resource hierarchy called Region 1 Sales.
